liquid logic remix 79
so i've got my remix 79 torn apart and ready to put my dagger pedestal in. all of a sudden it dawned on me that the boat is sitting higher in the bow than the stern. the boat has assymetrical rocker, something i've never encountered, even with other kayak conversions. i could use some help with trimming it out. should i place the pedestal so it sits in the water the way it is sitting on my garage floor? the website says it has four more inches of rocker in the bow. my local boat shop told me to trim it out that way or slightly forward. are there any words of experience out there?
thanks,
jim
thanks,
jim
- CosmikDebris
- marclamenace
Love it; high bow stays over features and lower stern gives a lot of speed in a neutral paddling position. Paddling forward the boat spins on a dime and carves well enough.
Yes it has to be higher bow on water a bit... Also depends on personnal perf... Always good to tuck tape it for a first try I would say.
thanks
thanks guys,
i think i'll duct tape it in and paddle some flats with it tomorrow. then i can move it around and see how it rides. it just kind of threw me off when i started thinking about saddle placement. i'll leave the bow high either way.
- Bruce Farrenkopf
update on the remix 79
I was able to get my boat into a local pool today to try different saddle placements. I ended up with the boat sitting very much like it sits on the floor. the bow is a little higher than the stern. I haven't tried to add a link here so let me know if it doesn't work. having the saddle in this spot created the best glide out of the hull. i was really surprised to feel edges while in the water. when i first got the boat i was a little worried about the rounded nature of the bottom. although there weren't any thigh straps and the saddle wasn't attached at all i was able to carve the boat. it did slip a little when getting started but seemed to track well once i got a little speed. if linking to mountainbuzz works i can take some more pictures as i go.
http://www.mountainbuzz.com/forums/memb ... ms162.html
- Bruce Farrenkopf
- oopsiflipped
i'm 185 to 195 and had mine seat back 7.5 to 8 inches forward. boat is 27" wide, and if you put thicker pads under knees you can get them quite wide. i really like the remix. it goes over hydraulics well, stays on top of squirly water and boofs great. it is so easy to paddle that i found myself getting lazy in it. it makes a great c1, but i decided i enjoy a creek boat with more edge.
I'm putting in a dagger pedestal, just for reference, and it came to me with one inch knee pads. I've duct taped another one inch on the inside edge of those knee pads. i want to make sure that i don't need the forward most thigh strap attachments before i glue them in, the knee spreaders that is. anyway, i could easily go farther than that if i needed to. i'm really surprised how stable the boat feels with that configuration. i can't wait to get it on moving water. i was hoping for a new year's day run, but it won't be ready and it is dumping snow here now. i do like snowboarding all day and coming home to work on my boat though!
- Bruce Farrenkopf
the boat looks big sitting in my garage but when i get in it it seems pretty short. i am 6'1" and weigh 170 pounds. after attaching the front of the saddle to the existing kayak bolt holes i think all i need to do is extend the back pillar just to keep the rear of the saddle down. it seems pretty solid with just the two bolts up front.
outfitting pics
i've uploaded a few more pictures of my boat today. they show the saddle and thigh strap attachments. i moved the thigh straps to the forward most position and added another inch of foam on the inside of my knees. here's the link: http://www.mountainbuzz.com/forums/memb ... ms162.html
