I have the fiberglass version and was wondering if it is possible to shorten it by 2"? It seems pretty simple, cut the grip off, remove the old shaft from around the grip and re-insert?
How long is the stub on the grip? If I cut 2" will I get into that?
Any reccomendations on what brand epoxy to use to reset the grip?
Thanks, Mike
Shortening a Werner Bandit paddle
I have done this to my bandit. The hardest part would be removing the shaft from around the T-grip, this is easier said than done. What I did was make my own grip, not real hard and I think the one it comes with stinks any way.
As for epoxy get some marine grade stuff, west systems for example. I didn't have any at the time and used the stuff from the hardware store and had to re-do it after some hard use.
wood
wood
Will dance for rain
Give Werner a shout and ask them.
