Boat Loading Systems
SlovenOC'er
Post by SlovenOC'er » Sun Feb 06, 2011 12:13 am
Got a new Topper on my truck. Problem is that roof racks are over 7 ft. off the ground. Other than befriending an NBA center to always paddle and run shuttle for me. I'm looking at boat loaders to help the vertically challenged hoist canoes up. We've used Yakima over the years and since we have accumulated a bunch of add-ons, we'll want to stay with them. Yakima has a few devices to help. Checking the Showboat Roller in particular. Anyone used one? Any other ideas?
rockyboater
Post by rockyboater » Sun Feb 06, 2011 2:38 am
Get a small booster step and keep it in your truck :D
Pierre LaPaddelle
Post by Pierre LaPaddelle » Sun Feb 06, 2011 2:46 am
Hey Sloven
I, too, have 7' racks on my truck, and I'm definitely a short-a$$.
Shoving boats onto the racks is easy, long as you do it from the back, not the sides.
But for tying down -- I invested in aluminum running-boards for da truck. Works wonderfully well for me. I've had 'em for the last 3 trucks I've owned, and I wouldn't consider doing without them.
G'luck!
Rick
C'est l'aviron. . . !
canoemid
Post by canoemid » Sun Feb 06, 2011 2:54 am
I've been looking for a boat loading system as well. I have the Yakima Boat Loader, but you have to lift over the height of one of the crossbars from the side. The Showboat looks good.
I just discovered you can use a Wheeleez Kayak/Canoe Cart as a loader from the back of the truck. The tires look large enough and spread apart enough to handle a canoe rather than smaller loader systems. Haven't tried it yet.
Any other ideas out there?
Wendy
Yakama loader
Post by Wendy » Sun Feb 06, 2011 3:04 am
The simple bar that slides out from the side. Walk up put bow on rack then other half with a step stool assist
Lappie
Post by Lappie » Sun Feb 06, 2011 3:23 am
One person on the truck the other one on the ground, the one on the ground pass the boat to the one on the truck and so on... If alone, put one end of the boat agains the top of the canopy and climb on and pull to bring the boat up!!
Smurfwarrior
Post by Smurfwarrior » Sun Feb 06, 2011 5:28 am
Get a hitch mounted cargo carrier and use that for your new blackfly, and any boat shorter than 8.5 feet. Thats what I do :)
Dennysdad
Re: Boat Loading Systems
Post by Dennysdad » Tue Nov 07, 2017 10:27 pm
I realize this only affects a few but a octane 91 92 will fit inside
A yukonxl/surburban bow first up against passenger seat
Stern to the left side
Best part you can keep it fully loaded
I.e. Throw bag,spare paddle,pump whatever else inside
Will work upright or on its side
Get some strange looks when I slide it out
Could probable go all the way to river
Mike W.
Post by Mike W. » Wed Nov 08, 2017 1:50 am
GM trucks are jacked up in the back from the factory. I put 2" drop shackles on the back to level the truck. That puts the rear cross bar at 6'6". Prior to doing shackles I thought about a step stool.
For boats that aren't heavy (40 lbs. Or less) even up to 18' 6", I load from the side by myself.
8' or shorter boats go in the bed. They'll fit diagonally and everything will close with a 6.5' bed.
For the 78 lbs. Scout, I load from the back. I put the bow on the rear cross bar with the stern on the ground, then pick up the stern and walk it up to the truck sliding the boat forward on the rear cross bar.
