Paddle Grip
Paddle Grip
Does anyone have any suggestions to add some grip to a paddle shaft? I tried some climbing tape but all the sticky eventually started coming through.
Dave
Dave
Re: Paddle Grip
What kind of a grip? For bare hands? For gloves? How much of a grip? I wouldn't cover my paddle with sand as I like to slide my lower hand along the shaft according to what I need to do, sometimes mid-stroke. I understand that this is exactly what you don't want, do you?
Paddle solo, sleep tandem.
Re: Paddle Grip
There was a long thread a while back on this. The stretchy-style electricians tape seemed to be favored by many, although that thread was about reducing shaft-wear, if I remember correctly.
Re: Paddle Grip
For gloves and bare hands.
Just looking something to leave on the shaft so its not all slippery. I had some climbing tape on it but the water made the sticky come through and would gum up my hands which I didn't like. I tried hockey tape and the same happened.
Dave
Dave
- busterblue
Re: Paddle Grip
I think this was the post that Shep referred do:
viewtopic.php?p=85250
I've been using the foamy-grip stuff that's made for bicycle handlebars. A little electrical tape at the top and bottom prevents it from unraveling. I initially used it for gription when wearing gloves. But now I use it all the time. The downside is that it's not very durable. I just wrap up about a 6-inch area--where my hand is 95% of the time. It doesn't stop me from changing my grip when needed. If you wrap too low, it will wear off against the gunnels.
Re: Paddle Grip
brush some epoxy on the shaft and put some fine powder (filler) or fine sand on it
imagine
Re: Paddle Grip
I put electrical tape wraps 3 inches apart on the shaft. It has worked well for a month. I used to be annoyed by my hand slipping on the shaft, but this has solved the issue for me.
Re: Paddle Grip
100 grit sandpaper, AND, de-grease your hands with river mud before paddling.
JKaz......
Re: Paddle Grip
I ve used cross country ski wax. It's grippy but it comes off and will make your gunnels black and sticky.
I find i only slip when I wear mitts. A short wrap of duct tape of gorilla tape helps. Take it off in the spring so your hands don't get sticky.
Re: Paddle Grip
What Kaz said. My go to paddle has a dynel,I think, sleeve on the bottom half of the shaft. It seems to collect body oil, sun block etc so I also wash it with sand dirt. My bare wood shaft is much less slick.
Bill
Bill
Re: Paddle Grip
Interesting... My lower hand never grips the shaft tightly. Having the shaft "sticky" would drive me crazy.
- Todhunter
- Ridge Spirit Outfitting
Re: Paddle Grip
Like Larry said, I use Sex Wax on my shaft. ![:P](./images/smilies/icon_razz.gif)
Matt Todhunter
