leaking airbags what glue to use?
Lennart
Post by Lennart »
Hi
what do you use to repair airbags? I got two leaking bags.
1 blue voyageur bag
1 blue mobile adventure bag.
Budget is low and airbags are not easy to sell over here , so repair is I hope the easy option to keep me afloat. :)
Thank a lot
Propper Writing in English, how do you do that, with dyslexia, bad hand eye coordination, ect. and in a foreign language
sorry fore all the mistakes.
2opnboat1
Mohawk Canoes
Post by 2opnboat1 »
I suggest shoe goop
Richard Guin
Lazy good for nothing slacker
ezwater
Post by ezwater »
I use Aquaseal and/or Seamgrip. Seamgrip soaks into surface fabric of airbags very effectively, but Aquaseal is better for larger holes.
padlcnu
Post by padlcnu »
I think a patch works much better then just glue. Use Vynabond for the glue and a piece of an old air bag or other vinyl. Also look for Thermarest patch kit, they work great too. :P
phreon
Post by phreon »
I've used Aquaseal on small holes and wear spots with great success. I don't think I'd rely on it for big holes, significant rips or problems at the seams though.
Phreon
sdbrassfield
Supporting Paddler
Post by sdbrassfield »
2opnboat1 wrote:I suggest shoe goop
Shoe goo x 2 ... spread it on thick, makes a good pliable patch.
SYOTR
coloradopaddler
Post by coloradopaddler »
i had to repair some air bags last summer. on the holes (pinholes), i used aqua seal with an air bag material patch. on the seam leaks i just used aqua seal. they all seem to be holding well.
golder
Post by golder »
another vote for aquaseal here.
Scott Free
Post by Scott Free »
Auquaseal or Seamgrip. As for the patch, any material will do. It doesn't have to be vinyl or airbag material. You could probably use burlap. The sealant does the work, and will make any material you choose airtight.
TheKrikkitWars
Post by TheKrikkitWars »
Black Witch or Bostik 2402
fleckbass
Leaky Air Bags
Post by fleckbass »
I had two that were leaking around the valve. I ran a bead of Vinabond around the valve and they are good to go!
I went raftin' once. I think it was in Ohio.
http://www.easternpaddling.com
