Should I store my SL'Edge with ash gunnels inside in winter?
canoeman61
It is a "SL'edge because it is an original model heavier than a sledgehammer. Winters are not too bad here but it can get down in the low teens or even single digits on occasion. I can make a cozy spot in the basement for it but wanted opinions from Yankee boaters as to if this is necessary.
Re: Should I store my SL'Edge with ash gunnels inside in win
You should be fine storing it outside as long as it's out of direct sunlight
The biggest worry is big temperature changes in short time spans...and more of an issue with royalex/wood...and more of an issue with longer boats.
- Smurfwarrior
Actually- the SL'Edge is the 'short L'Edge'. Here is Matt Thomas running Baby falls in it- https://www.facebook.com/photo.php?fbid ... =3&theater" onclick="window.open(this.href);return false;
SkeeterGuy86
that thing has the stability of a beach ball ... if that ... but i will admit ... it was fun to paddle down the Tellico
SG86
I told Smerda that I might be interested in a "long" L'Edge. Definitely not interested in a shorter boat.
If it has ash gunwales, I would be inclined to store it indoors. Ash is a little above average with regard to wood rot, but even something tropical like mahogany is better off indoors.
