Mohawk Maxim Outfitting Adventure
horizongfx
Post by horizongfx »
Been working on this for 2 days now, Kinda Used the Smerda Saddle as a jumping off point on this One, I'm real happy with the end Result, Enjoy...
http://horizongraphics.biz/BoatWeb/index.htm
...........O
......(___|/____)
dwd58
Post by dwd58 »
That is a very nice set up!
cheajack
Post by cheajack »
Aw3ewsome job on the saddle. Hope you saved the templates. Where is the battery?
ckingoc1
Post by ckingoc1 »
Good job, that looks great!
2opnboat1
Mohawk Canoes
Saddle
Post by 2opnboat1 »
Nice job bob Yhea I want those templetes I think I have a use for them
Richard Guin
Lazy good for nothing slacker
D-Caption
Mohawk Maxim outfitting
Post by D-Caption »
Very nice job. Did you make your cuts with a band saw or with hand tools? Did you glue the top section to the saddle or leave it loose so you could put it in the new plastic Maxim? Just wondering what your saddle height in the extrem rear under your butt. Thanks in advance D-Caption
horizongfx
Re: Mohawk Maxim outfitting
D-Caption wrote:Very nice job. Did you make your cuts with a band saw or with hand tools? Did you glue the top section to the saddle or leave it loose so you could put it in the new plastic Maxim? Just wondering what your saddle height in the extrem rear under your butt. Thanks in advance D-Caption
Most of the Cuts were made with a Bandsaw, however some of the More Intricate parts were cut with a handsaw.
At the Extreme Rear the saddle Height is Now 8" it started out 9" but I cut it Down and Flattened it out a bit.
It slopes up forward so it is Higher at The crotch between the Knees.
I saved the Template so when The PE Maxim does happen I can do it all over again.
:wink:
...........O
......(___|/____)
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
That's awesome man! :D
C-boat outfitting is something that most kayakers will never understand.
You've got it down my friend Image
jim gross
Yep
Post by jim gross »
Ya know for some reason I always thought the handle stood for "Horizon Girl Fox". hahaa. One question, shouldn't that thrust schnozzle point out da back like a jetski insteada out da front like a water fountain boy? Great outfitting job. I want one in PE.
Jim
kabuki_blaze
Post by kabuki_blaze »
Very Nice work! Thanks for sharing.
Re: Yep
Looks sweet!
jim gross wrote:Ya know for some reason I always thought the handle stood for "Horizon Girl Fox". hahaa. One question, shouldn't that thrust schnozzle point out da back like a jetski insteada out da front like a water fountain boy? Great outfitting job. I want one in PE.
Jim
Maybe his foward stroke is better than his back stroke?
Dooleyoc-1
Post by Dooleyoc-1 »
Looks sweet!
mr ray
Post by mr ray »
Sexy!
I want one of those drill bits.
horizongfx
mr ray wrote:Sexy!
Just get you an aluminum arrow and a pipe cutter, works great for drilling clean holes in minicell.
use an air nozzle to remove the Foam plug from the tube after cutting p.s be careful were you aim it when you blow the Plug out !!!
:wink:
...........O
......(___|/____)
gumpy
Post by gumpy »
hey when i get my maxim will you send me a copy of the templates?
Joe
