my statement about OC1 being safer than K1 came from the following....
#1 - In a kayak it takes longer to get out of the boat - this makes you more susceptible to strainers
#2 - In a kayak - you are much more susceptible w/ getting pinned(vertical).
#3 - In a kayak - you are much more susceptible to shoulder injury
#4 - In a kayak - you are much more susceptible to smashing your face underwater
#5 - while this hasn't yet been fully proven -wearing a skirt causes shrinkage of the male genitals
#6 - In a kayak - you start with a bombproof roll - so you never learn how to effectively swim the gnar.
#7 - In a kayak - you don't have 8inchs of foam underneath your butt, so you are more susceptible to back injury from boofing flat.
#8 - In a kayak - everything is easy, so you have to run the brown all the time... and history shows that running the brown all the time - will take u down.
#9 - a swamped kayak floating down the river, takes forever to get to shore, and is a serious hazard to anyone down stream of it
#10 - In a kayak -if you get knocked out.... you will not come out of your boat(see gorilla a few years back)
#11 - in a kayak - your line of sight is lower to the water than a canoe - thus giving you less time to see potential hazards ahead
#12 - in a kayak - you are much more susceptible to a boat that is bigger than you, running you over( canoe)
.......ok some of these may be a stretch - but you get the idea......
