ReOutfitting a OC1 Questions
sganarelle
I have removed all of the old outfitting from my boat, a Dagger Genesis. How much of the old glue should I remove before glueing in the new outfitting?
What is the best way to remove the old glue? Light sanding? Light use of Acetone?
cmnypny
Actually according to Brian Shields who does the outfitting for Mike Yee up in my neck of the woods:
Take an old rag and thoroughly soak it in varsol.
Put in over the area of the boat with the old glue. Let it sit there overnight.
I used a 3 inch wide pastic scraper after that to take off the crap. It should come off pretty easy.
Afterwards clean the area well and wipe it down with isopropol alcohol.
I have doen this a couple times and it works for me.
sganarelle
Neg Johnson on the chisel idea... thy last effort shall be to not damage the vinyl layer.
Remove the remaining adhesive with a rag dampened with paint thinner and leave overnight and use light pressure with a putty knife. The adhesive will roll off like a snot on your fingers- no personal experience with the snot, read it elsewhere... BT perhaps..?
Ditto,
Kevin
Ditto,
Kevin
I thought Varsol was outlawed?cmnypny wrote:Actually according to Brian Shields who does the outfitting for Mike Yee up in my neck of the woods:
sganarelle
sganarelle
