Hello Cboaters,
I just outfitted a new Taureau and thought I would share what I did.
http://blog.jamesweir.net/2009/11/pimp- ... white.html
I think customising your canoe is a vital to optimal performance. And as it says in the blog if you wanna know more, drop me a mail.
Stay safe
James.
Pimp my ride
funkidreadz
- marclamenace
Re: Pimp my ride
Dittofunkidreadz wrote:I think customising your canoe('s outfitting) is a vital to optimal performance.
James.
Great images and text.
I loved the
A very impressive outfitting package, including how you put it all together for your site/blog. Much appreciated.
I loved the
I'm a little surprised at the location of the rear D ring for the thigh straps, as it is over or above the ankle/heel. I guess it works well there for you.Drain pipe, some old strap sewn together and a nut and blot. a super easy strap anchor system
Outfitting looks great! How well does the pipe stay put as a thigh strap anchor. I have an old boat which the previous owner did not attach the thigh strap anchor d-rings to very well, and it's pulled up a bit of the outer layer of the inside of the boat. I've been struggling with finding a method for a new thigh strap anchor, as this d-ring is right where I would need one to be. Just seems like rolling etc. would put a ton of stress on that pipe. This may have to be my solution though, I can't come up with anything else short of a full bulkhead, and I much prefer thigh straps with no bulkhead.
funkidreadz
Thanks for your encouraging comments.
@Paddle Power
@Peter
There is no problem with with the drain pipe slipping, I choose a diameter that is a bit bigger than the equalisation tube so it is squashed in. The foam on the hull also keeps the pipe from falling out.
I have used this style of system for several years and never had a problem with the saddle falling out or the pipe breaking.
Paddle safe
James
@Paddle Power
Yes the rear D ring is over my heals, the advantage is that I am very well strapped into the canoe, the disadvantage is that I only come out when I release the straps, I can roll so no big drama!I'm a little surprised at the location of the rear D ring for the thigh straps, as it is over or above the ankle/heel. I guess it works well there for you.
@Peter
Paddle safe
James
