Happy to say that I am very pleased with the Ocoee purchase. Bags are in and I've been on the Haw and the Cape Fear so far. I'm not 100% dialed in on the boat yet, but getting very comfortable in it. I've played a little, enough to find those edges and get a feel for how they react, but not enough for those edges to have me viewing the fish yet. I did get to swim once when trying to block a big wave by quartering too far, but that wasn't the chines.
A couple of things I've found so far on the boat (just in case a newer paddler is nervous about hard chines).
Initial stability isn't great, but it isn't that bad either. Feels a little loose to start with but slightly weight it to your onside and you are there.
Secondary stability it very solid. The transition from primary to secondary is not progressive..it's loose, then all of a sudden it's all there. A decent low brace is a good thing to know, just in case you aren't patient enough for it to kick in;).
The chines do catch when crossing an eddy line, especially if you do not lean the boat correctly. Scary the first few time, but also very fast and predictable. It's not something that happens once in a while, it catches the line every single time, no questions asked...get used to it and it's a blast
For an 11' boat, it surfs well. Use the chines and you can shoot back and forth almost at will.
You can actually paddle the thing in a straight line pretty easily if you watch your stroke mechanics. If you don't keep the paddle vertical, you'll wear yourself out with corrections...do it right and it tracks well.
The boat seems to like to go with the current...if you're on the tongue, it will stay there unless you move it...if the current goes around an object that has a pillow, it will follow around nicely...very nice
It's kind of like bouncing off a seam when you have the wrong line crossing an eddy.
If you want to turn quickly, keep the boat flat and it will spin on a dime. drop the chine if you want to carve a turn, but if you just want to do a quick 180, keep it flat.
I guess, bottom line, the Ocoee is a very fun boat. It is not as progressive or forgiving as some boats but it is also very predictable. To me, predictable is better than forgiving in the long run. If a boat will let me get away with a mistake 4 out of 5 times, I'm betting the 1 time I don't get away with it will be the worst time. I'd rather it smack me 10 out of 10 when I make a mistake so that I know I'm doing it wrong and correct it before it becomes a habit. I don't think it is a boat that will mislead you on your abilities....it provides instant feedback on what is right and what is wrong...tough for a beginner maybe, but l think it will make you a better paddler in a quicker fashion than one that lets you get away with a lot.
Jeff
