BUT, it's been 50 and raining, so, unless I wanted to squeegee the trails they figured they didn't need me today...
So, I worked on the Maven:)
Outside seams are done
Cockpit rim is laid up
Thigh strap ancors are glassed in
So, what's left?
-Trimming and a bit of sanding of the cockpit rim
-Neatening up the seams, if need be
-Endpours (microspheres from Sweet Composites expected Tuesday
-Install minicell pillars
-Install temp seat (integrated with the rear pillar, no set back yet until I figure the trim out)
-Install knee pads
-Install thigh straps (I have several sets hanging around
I forgot the camera today, but will try and get pictures on Monday, assuming I bring the boat home then to finish it (which is my current plan)
The black seam (2 layers of 1" bias tape (15 oz nominal per layer), pigmented WEST systems epoxy) and cockpit rim really add a lot to the boat....
C U soon
Adam and...the Maven
(Yes, Mike, I am most likely more excited than you are right now!)
