The first boat had to have a gel coat (for mold breaking-in purposes), and for better or worse all they had was light grey. Actually looks pretty good in light grey...and I'm planning on black seams and cockpit rim
The layup is pretty light, but will be a good test boat.
It is a "full cut" boat...they can get MUCH smaller but not really any bigger....
Length seems to be exactly 10' in the full cut version.
Width is around 23-24"
, widest point just behind the cockpit. While this most likey seems shockingly narrow to most folks, I found it worked rather nicely in the prototype. The hull design, low volume, and high volume "turret" contribute to the stabity you feel. Prototype stabity was MUCH superior to the Oxygen (hull is too flat) and Wildwater boats. It will have less stability than you're "normal" cut down slalom boat...however it should have increased cartwheel-ability...not to mention downtime possibilities
I'll post again when the outside seams / cockpit rim are laid up
Then, it's just a "simple" job of outfitting, and off to the pool on a Thursday night
I KNOW I'm a bit biased in saying this, but the boat actually looks better in person than on-line
