Looking to beat up the ends of my blink and don't wanna mess with wood.The mohawk plates on my viper would fit the bill but are a little longer than I want.
Any suggestions.
deck plates
deck plates
Proud Yankee
Re: deck plates
I think you need to get creative there too with some eyeliner on the ends! Lay up something in glass / Kevlar for more style points.
just say'n!!!
just say'n!!!
Re: deck plates
Was looking for less work and more protection then laying up some clothe I have gotten into the (bad)? habit of setting/pivoting boats on their nose when lifting and dumping, so wanted something that would rap around a bit like the mohawk plates. Thought about just cutting ones off the ledge but red wouldn't work, and the mohawk plates are just a touch too long.
Proud Yankee
NickParker
Re: deck plates
HDPE sheet. Comes in various thicknesses, is easy to cut/machine, is tough as nails, and is UV stable. King Starboard ST is a brand name that is good. It's not cheap, but there are some places that sell/cut smaller pieces, such as:
http://www.boatoutfitters.com/king-star ... ArGC8P8HAQ
If you have CAD skills, draw up what you need and have it cut on a CNC router. Cabinet shops, or places that build exhibits for museums & tradeshows will have that type of machine. HDPE cuts nicely with standard router bits.
You can also hand cut/machine it with standard woodworking tools. It does not sand well, so it is best to make a clean cut with a router. If you do need to sand/file, brief exposure to a torch flame will smooth out the finish.
It can be glued with the proper technique & epoxy, but it is best to avoid that if you can. If you have to glue it, follow the standard recommendations from West Systems:
http://www.westsystem.com/ss/gluing-pla ... lex-epoxy/
I'm not associated with these companies in any way. I have machined a bunch of Starboard, it's good stuff.
Re: deck plates
I have new Blink #15 and realized same problem immediately. Deck plates are carbon/basalt. Purchased Surlyn film (for protecting ski/snowboard tops) 14" wide, $2.95/ft from Tognar.com. Laminated entire deckplate and bow/stern ends at deckplates. Then a little gorilla tape on very tip of deckplate over Surlyn film where bow/stern would contact ground. Film is easily to peel off and replace if necessary. Part# TYC 7210 Skuff Saver Tape.
Re: deck plates
Kaz you forgot to add to paddle AROUND rocks not through them!
Re: deck plates
Sounds like a job for a couple of cheap plastic chopping boards....
Would be a shame to add a lot of weight to a Blink....
