C1 knee strap placement
Re: C1 knee strap placement
That's how I'm set up - the big binding over my knees (low) and 2" webbing for upper straps with a quick release. My quick release is attached to a strap that goes out to a security bar on the deck (Velcro keeps it in place). In theory, someone else could release my straps and skirt. In practice, it is probably overkill.
ClassFive Boats
IMO I highly reccommend a bulkhead for your knees with 1 set of straps rather than another set of thigh straps. It will help keep the cockpit form collapsing in case of a pin, adds flotation as well , and a lot easier to get in and out of your c1.
Agree with gonzo that the ratchets are terrible realease mechanisms. I don't like them for thigh straps for that reason. I hear there are some that work good but I haven't seen them.
I can't imagine getting in trouble when the strap is way down at the knee though. If the straps are low they will be no match for you in any case. IF needed, you'd have enough leverage to rip them to shreds and not even feel it.
And yeah, it's the ankle straps, and there are a lot of different shapes. If you have a ski shop around, ask to look through the scrap pile.
I have a slightly different suggestion for how to mount them: Get an old boat, and cut a big section out of the hull, going far enough up the sides to have the footrest bolt-holes... Now build your outfitting onto that (I have snowboard bindings attached with blind rivets, and a u-bolt with a snap shackle for my thigh straps, plus some foam knee-cups on mine)... now bolt the plate to the boat with the foot-rest bolts from the kayak you're converting.
You've now got a better supported hull (less likely to crack from a side impact), the outfitting is mobile from one shell to another with minimal effort, and no extra holes in your boat.
* Which is actually fairly reasonable when compared to EZwater's for instance
** The one that made me change my mind on bulkheads requires you to climb out whilst clinging to a branch a few yards above a portage, because there are no eddies leaving that the only way to get out and clamber round it
Even with them fairly high up the leg, I've escaped a set by pushing hard and blowing the ratchet mechanism to pieces (badly bruising my legs into the bargain) when the release mechanism failed to operate as intended... irritating, but also kind of comforting to know that it was possible.Larry Horne wrote:I can't imagine getting in trouble when the strap is way down at the knee though. If the straps are low they will be no match for you in any case. IF needed, you'd have enough leverage to rip them to shreds and not even feel it.
I used to use that as my go-to outfitting solution, but with the size of my legs* getting out of the bulkhead and then boat at a less than ideal getout** was always an issue, so I decided to switch to double straps in my creeker, I've gone through a couple of iterations of strap layouts, but all have been much better overall than a bulkhead for the intended purpose of the boat... where I want maximum control in my playboat and slalom boat I still prefer bulkhead & straps; but the ease of entry/exit for double straps is a winner for creeking.ClassFive Boats wrote:IMO I highly reccommend a bulkhead for your knees with 1 set of straps rather than another set of thigh straps. It will help keep the cockpit form collapsing in case of a pin, adds flotation as well , and a lot easier to get in and out of your c1.
- busterblue
I did something similar with a sheet of 1/8" HDPE plastic. I'm pretty happy with the result, but I did not have the foresight to leave enough plastic for the knee straps. The problem I ran into was trying to cut down the rectangular plastic sheet into a shape that would conform to the curved hull. Since there's rocker in one direction, and the curved sides in the other direction, you can imagine it was like trying to press sheet of paper into the bottom of a bowl -- it won't sit flat without buckling. So I cut away at the plastic sheet, leaving "arms" that reach to the old foot rest holes. I can see that using part of an actual kayak hull could fit much better. Oh well, I guess there's always next time...
Bulkhead? yeah, not a bad idea either. I'd love to nail an adjustable bulkhead - mine works OK, but only adjusts through a limited range (enough for me, but won't get small enough for others).
A "plate" (sheet of PE, boat or otherwise) - yep, that works, too. I wish I'd trimmed mine more - the boat is a bit heavy.
Take a look here, start at the 3rd one :
https://picasaweb.google.com/1038689084 ... directlink" onclick="window.open(this.href);return false;
How heavy is using an old boat hull for an outfitting base?
Not all that heavy, certainly much less than the kayak seat it replaced; I trimmed off most of the bits not needed to support outfitting or attach it to the boat minimising the weight gain...Paddle Power wrote:How heavy is using an old boat hull for an outfitting base?
It's in the region of about 1kg (2.2lb) of plastic, plus another 0.7kg (1.5lb) in fittings, bindings and foam bringing it in at a sum total of 1.7kg or 3lb11oz...
Result, my boat is much much lighter than a kayak would be, almost as resistant to deformation from the side and somewhat lighter than my previous c1 which was rammed to the eyeballs with (expensive) foam.
Sound good as well as lighter than I expected.
- Todhunter
- Ridge Spirit Outfitting
TKW-
Chopping up an old hull sounds a lot like that custom C1 outfitting that someone made and sold on here a few years back. I always thought that guy's outfitting looked really cool, but I couldn't pay what he was asking. I may give this idea a shot the next time I outfit a C1.
Matt Todhunter
That was "j not Elvis" Robbins and his etc "plate" outfitting. Cool idea, but a hard to sell to us cheap paddlers.
I trimmed mine back as aggressively as possible, to minimise the weight... If you used a bigger section of hull (going right back under the saddle (I use LL center rail as the basis of my.convertions, so not much need) then it would be accordingly rather heavier.Paddle Power wrote:Sound good as well as lighter than I expected.
J "Not Elvis" used to create outfitted inserts for converted cboats (k1 to c1) using a plastic sheet. He may not be doing that any more but here is the link to what is on this website:
Team ETC k12c1
I owe him a lot for helping me out several years ago, but DO NOT tell him I admitted that.
Team ETC k12c1
- Todhunter
I dug, and I was actually thinking of Larry Horne's outfitting: viewtopic.php?f=2&t=7963131" onclick="window.open(this.href);return false;sbroam wrote:That was "j not Elvis" Robbins and his etc "plate" outfitting. Cool idea, but a hard to sell to us cheap paddlers.
I guess he didn't use a hull, but his outfitting bolted into the stock location like TKW is talking about.
Matt Todhunter
Larry Horne's outfit is bad-@$$ as sh!t
