Stock thwart lengths for Esquif Prelude?
Posted: Thu Sep 19, 2013 1:03 am
by caverdan
Hi!
Trying to find out the lengths for the stock thwarts for an Esquif prelude. Bolt hole to bolt hole is fine.
Thanks!
Dan
(And yes, I already searched...)
Re: Stock thwart lengths for Esquif Prelude?
Posted: Thu Sep 26, 2013 7:31 pm
by caverdan
Still trying to find this out. Any help?
Posted: Thu Sep 26, 2013 10:39 pm
by PAC
bolt to bolt 23", overall 24.5" - Not sure if its factory - its an older original pyranha and 2nd owner. Hope that helps.
Posted: Thu Sep 26, 2013 10:43 pm
by c1swim
Well, on my Pyranha Prelude, it is 22 & 13/16" from center to center of bolt ,both front and rear thwart.
Factory,
So.......maybe.
Posted: Fri Sep 27, 2013 12:35 am
by milkman
On my ESQUIF Prelude, the forward thwart is 22-3/4" bolt hole to bolt hole. The stern thwart is 23".
Posted: Fri Sep 27, 2013 1:08 am
by caverdan
Thanks guys!
Posted: Fri Sep 27, 2013 3:33 am
by c1swim
Like a snow flake.... No two are alike.
Posted: Fri Sep 27, 2013 3:54 am
by ezwater
If we really mean Esquif, it might be possible to grab the excellent line image from their website, and calculate dimensions based on the known length. New math and all that.
Posted: Fri Sep 27, 2013 12:56 pm
by PAC
Or ask Esquif directly. Got to beleive they would get back to you on this one....
Posted: Fri Sep 27, 2013 2:29 pm
by caverdan
Well, Esquif reports a "width" of 25" for the 'lude. I was trying to figure out if this was at the tumblehome or the midpoint of the gunnels, and thanks to your help, I found it must be at the midpoint of the gunnels. The tumblehome is several inches wider when using the thwart dimensions given here for Esquif boats. I figure the Pyranha boats are a tad different and don't want to compare apples and oranges.
Anyhow, I cut the new thwarts last night, and went with an overall width from outside of midpoints of the gunnels of about 25-1/2" to try and eke out a tad bit more stability. This is still narrower than the same measurement point on our Viper, so it should be OK in terms of reach for cross-strokes.
Thanks again for the help!
