[Video] Bilge pump installation in an open canoe
Posted: Fri Jul 26, 2013 10:12 pm
I've just installed an electric bilge pump in my Esquif L'Edge, and made a short video, hopefully to help others understand the basics.
If you paddle whitewater, especially tight, technical sections that don't allow much room for emptying water that you take on board, a bilge pump is a valuable addition. This video outlines the installation process and materials needed.
A number of saddle modifications are useful, to allow the saddle to be removed quickly, but still have it securely in the boat when paddling. These include the addition of knee wedges that also anchor the front of the saddle laterally, and a three-sided piece of foam glued at the rear of the saddle to secure it. Screws through the thwarts, into dowel inserted in the bulkhead and saddle, prevent longitudinal movement.
Finally, if you paddle an Esquif L'Edge, or similar boat with the carry handle oriented longitudinally, rotate it 90 degrees and fix to the deck. Use the spare screw holes to secure the ends of the airbags with cord.
http://www.youtube.com/watch?v=XJ3txIUbCzo
