Help with ABS Slurry
Posted: Sun Apr 13, 2008 2:05 pm
by cheajack
I'm ready to slather some ABS/Acetone slurry to bare areas on a hull and wonder about the consistency of the mix. I understand that if it is too "wet" it can soften the hull. My mix is about the consistency of a milkshake and would easily pour out of the paint can it is in. Is this Ok? Should I add more ABS and get it a little thicker> I plan to have the hull slightly warm (heat lamp under neath) and moving air from a fan passing over it while it cures. TIA. Jack
use thin layers
Posted: Sun Apr 13, 2008 2:18 pm
by Jim P
Thinner layers will dry quicker and be less likely to deform the hull. The acetone will work its way into the lower layers and the whole thing takes a while to dry out. Just because the top feels dry, it is not. I recommend waiting a day or more between layers.
If you want to push it, be sure to provide support on the inside in case the hull softens and sags - been there done that.
Posted: Sun Apr 13, 2008 8:46 pm
by Blast
Jack,
Jims post was accurate with my experience. Here is a few other tips I have found. A piece of minicell foam make a good squeegy to apply the mixture. Tape off the area and only make one application pass...anymore and the mixture will pill and chunk up.
Good Luck
David
Posted: Sun Apr 13, 2008 9:16 pm
by cheajack
David, I used a 3" putty knife and stopped spreading when the ABS began to skin over. So far so good. The Ocoee took and A#% whipping last weekend on Island Creek.
Posted: Sun Apr 13, 2008 10:04 pm
by sbroam
At the right consistency - about milkshake - I find it is "self leveling" and if you over work it, it will "chunk up" as noted above...
Milkshake
Posted: Mon Apr 14, 2008 12:07 pm
by Jim P
Is that a McD's milkshake or a DQ milkshake?
Posted: Mon Apr 14, 2008 1:34 pm
by cheajack
Fruit Smoothie with honey and two scoops of protein powder
