Airbag Issues....
Posted: Fri Feb 09, 2007 6:20 am
Here is the problem,
I have made a nice cage for the airbag to go in..or atleast I think so. I put the bags in and I blow them up and it looks perfect, it is staying put and fits just right. Well after doing a few rolls/getting water in the boat the bags will try to get out the end. There is not way that they are going to get out but the problem is that they will make some gaps by moving the ropes around alittle. I did not have my camera with me at the pool tonight but below are some pictures of how the bags mangled things. I tryed running the rope through the two tie downs at the end of each bag but they will still shift around so much so that the corners of each bag will push above the gunwales when there is water in the boat. I cannot seem to figure it out., below are some pictures of how I have it tied down.
Thses three pictures are of my rigging after the pool. You can see how the bag shifted down and made some sizeable gaps in my netting. You can also see where I tried running the rope through the tie downs on the bag, that helped a little but it still made some sizeable shifts. Toward the bow you can see the gap on the right side where the bag has shifted down and to the left side of the boat.
These two are of how things look when I air up the bags, you see some sizeable gaps on the sides that allows the bags to shift when water is introduced.
This last one is of my netting job. there are some gaps on the sides but I have seen outfitting of other boats on the internet that also have these types of gaps. Do I need to spread out the net to better grab the sides of the air bags? Also how tight do these ropes need to be? My goal is to make it that the bags will not shift around in use but so far all of my attempts have failed.
