anyone make narrow open canoe thwarts?
Posted: Tue Oct 17, 2006 4:26 am
by parasight
does anyone make thwarts about 27" wide? I need a set for a dagger canoe I'm rebuilding.
most of the ones I've found were around 36" wide, making the narrowest part of the thwart just about where I would have to mount it to the gunwale.
the picture actually looks better than it is, that thing is about to fall off the boat.
Posted: Tue Oct 17, 2006 4:43 am
by Alan B
i think the traditional shaped thwarts are not all that necessary for a whitewater canoe. you can save some weight by using thwarts no wider than the narrow part of the thwart in your picture... or do 2- 3/4 x 1 inch thwarts... or do the X pattern.
Thwarts
Posted: Tue Oct 17, 2006 11:13 am
by Jon
It might be a Canadian thing, but I just used a chunk of shaft from a broken hockey stick. A little sanding and it looks fine.
Why not just trim off the extra? Or get a piece of hardwood
Posted: Tue Oct 17, 2006 3:28 pm
by boatbuster
Just trim evenly from either side. I also used oak, it is heavy but strong.
Yeah, I just make 'em up too.
Posted: Tue Oct 17, 2006 6:03 pm
by ChrisKelly
Depending on the shape of the hull when you will install them you may want to shape the ends of the thwat a bit to fit the boat shape.
Posted: Thu Oct 19, 2006 2:33 am
by parasight
thanks guys.. I'm going to go see how many broken hockey sticks my brother has.
