attaching T grip? any tips?
Posted: Mon Jun 27, 2005 12:43 pm
by James
attaching a wooden T grip to an aluminum paddle shaft. Any tips? I have a polyurethane waterproof glue I might try. First time I drilled a hole and used a screw to keep it in place, but the threads in the paddle shaft stripped soon afterwards.
Posted: Mon Jun 27, 2005 6:25 pm
by LEW
Try this, it has worked so far on wood to wood and wood to carbon. It is available at most hardware stores.
http://jbweld.net/products/index.php
LEW
Posted: Mon Jun 27, 2005 10:09 pm
by Bob P
It helps if the shaft and the wood are oval, not round, and the fit is nice and tight. Use coarse sandpaper on the inside of the aluminum tube and the wood. It will help the mechanical bond. Sometimes, I will drill several small holes in the aluminum or die-grind divits on the inside too.
