How does the Taureau stack up against other c1's?
xmas0c1c1k1
So I paddle mainly c1 but am thinking about buying a taureau. I am just wondering how this boat stacks up against c1 creekers ie jefe, burn. I know the whole open cockpit is a huge difference but what is its performance like speed, stability, boof?
It's not anywhere near as fast as a jefe, nor does it boof as easily (but what does boof as easily as a jefe?) so if you're coming from that background (i seem to remember you have a Grande?) then you'll need to adjust...
Given you'll need to adapt anyway (and coming from a jefe are already pretty good at balancing in boats), you might as well buy an open boat that looks like a canoe rather than one that: "looks like the business ends of two [ed: "adult toys"] stuck together with a cockpit in the middle"*.
*Not my description, but that of one of the guides i used to work with... it is, all in all unsettlingly accurate though
xmas0c1c1k1
xmas0c1c1k1
It's 6" shorter and 2" wider than a Jefe, and being flat bottomed, probably has a shorter waterline length too...xmas0c1c1k1 wrote:really slower than a jefe?
Buliding on what craig said as someone who has both a Prelude and a Jefe in their fleet, I'd say they were comparable, complimentary boats and I like both a lot... they feel kinda simmilar as both need you to drive them about, both move better if you make them follow a slight curve to a straight line and both can feel unstable if you just sit in the current twiddling your thumbs.
xmas0c1c1k1
It's not going to be awful by any means, but I certainly wouldn't replace my C1 with one (though I wouldn't replace my C1 with an Open Boat period, so I'm biased really).
xmas0c1c1k1
Yea I will prob be getting a stomper soon too but the 90's are just starting to get pumped out and when you arent paying as much mney as a kayaker on a boat they don't care too much Im pretty diehard to liquidlogic's designs in the past Im sure I will get a stomper but not at the moment just kinda want to mess with something new see what its all about
My recommendation is stay away from the Taureau, I had one set up as a C1 and expressed my dissatifaction with design, plastic, and rolling in other posts.Larry Horne wrote:(STOMPER!) with a 5 1/2- 6" saddle.
Like Larry, the Stomper is the boat that looks interesting to me as a C1, besides the Burn, Everest, Karnali or Villian. Besides the hull differences, the Stomper and Villian look to have more cockpit room and less of a dramatic change in the cockpit combing height from front to back.
If anyone converts a Stomper, please share.
