Foot"pegs"
hammerhead
Foot"pegs"
I need help placing some toe blocks in my creek boat. The situation is that I use the boat mostly as a big, cold water boat. When I occasionally paddle in warmer weather w/out the layering, fit becomes an issue. The looseness is causing some blown rolls & whatnot. Was looking for some suggestions regarding a flex toe block set-up.
- Smurfwarrior
This work for ya?
http://www.northwater.com/html/products ... locks.html
I have those adjustable toe blocks, and for me the jury is still out. I put them in partly for that reason of having different layers and also wanting to have my feet in different positions, but the one thing I have found is that I can't get rock solid against them like I can against pegs. They are definitely more comfortable than pegs, but it was hard as I was trying to roll the boat this weekend and I couldn't get snug against them. I still have to tweak some other parts of my outfitting, so hopefully when I change my strap configuration and knee pads, it will be more bomber. We'll see.
Chris Loomis
toe blocks
In my BigGun C-1 I have 1" high X 3" wide minicell blocks faced with neoprene. These are positioned against the side of the saddle so my toes BARELY touch. When I flip I dont slide back. To release, it is easy to slide toes to the sides or over top of blocks. Cheap and effective, no pressure on feet.
hammerhead
I hear some people can use toe blocks in a c1. I tried it a long time ago, but it didn't work at all for me. With a 5 1/2" saddle, my feet and ankles are flat on the hull and pointing all the way back. So I realistically can't push against anything.
You have the base there for an excellent strap setup that would solve your problem.
hammerhead
