Decked L'Edge Conversion
taoslightning
I'm looking to go topless with my L'Edge, love the hull but hate the deck. If anyone can supply some gunnel dimensions on their factory model I'd greatly appreciate it.
Also, does anyone have any experience cutting into rotomolded plastic? The way I see it, if I install ash gunnels first I can then take a palm router, with the bit's bearing resting upon those gunnels, and get a nice clean cut. I'm not sure how Esquif does it but the open L'Edges I saw at Gauley appeared to have been cut similarly.
Thanks.
Thanks.
As long as you don't cut it below this line you can put the gunnels where you want.
Basically the top gets removed sort-of as you described... I can shoot a few pictures of what the ends look like tomorrow and post them... or you can look at these...
http://www.facebook.com/album.php?aid=6 ... 175affb4f5
It's raining here right now.
Unfortunately it's probably a lot easier to install gunwales once the excess deck is cut away!
I'm sure you'll figure some appropriate tool and/or guide rig. Or just free-hand it and sand, what's the worse that could happen?
Keep us posted, it will be interesting to see more of the home-job quasi-decked L'Edges.
Pat.
Pat.
taoslightning
Craig, thanks for the graphic - I appreciate it. I'm going to install the gunwales directly underneath that top lip of the deck. What's the plastic, a 3/16 inch thick? If you can post those photos on this site, or email them to me, that would be great. Unfortunately my Lady does'nt let me have facebook .
Thanks again.
Thanks again.
Me and louie just finished butchering his ledge, and it turned out alright. We took a jigsaw and cut in the topside of the deck. We cut (I cut) within 2" inches of the edge of the boat and the overal opening when we were finished was 6' feet. I thought that it was sturdy enough that it didnt need gunnels but ole Louie is dead set on putting them on nonetheless. I'd post a picture but I couldnt get it on here.
Craig, maybe you can help. They're on his facebook page.
Team Blackfly
I'd consider doing something just like that (but with a bigger front deck Craig!), but hadn't thought of lining the drill holes with actual eye-things - nice touch, and probably a very good idea!
For the gunwales are something I'd absolutely plan to do, but would probably never ever get around to doing.
Looks good. Straight-up jigsaw seems to work!
Pat.
Pat.
- Smurfwarrior
- Smurfwarrior
taoslightning
taoslightning
funkidreadz
