alternative to a conventional pump
Just saw one of these *link* on woot.com (woot-off today).
This could be an alternative to a conventional pump. After swamping or rolling, just switch this on and let it float around spraying the water out until your boat is dry. You could tether it in if you were afraid it would get away.
That's a lot cheaper than an Attwood pump, switch, and sealed lead acid battery, too.
Brewbeer
Post by Brewbeer »
Someone needs to get one and test it. I would be interested in hearing other people's comments.
Wiggins
Post by Wiggins »
I find it strange that they don't list how many GPM it pumps. It is almost like they designed it for some other purpose!
Kyle
craig
Post by craig »
I can just imagine the comments from Louie when he sees one of these in a canoe! :o
monstertruckfred
Post by monstertruckfred »
It works like magic......... :D
jscottl67
Post by jscottl67 »
Just be sure you mount it behind the pedestal - not sure how it would work up front with offside strokes. ;)
jroneil
Post by jroneil »
only 2 left better hurry!
cheajack
Post by cheajack »
Should fit nicely in a boofing white Mohawk
mechnginear
Pump altenative
Post by mechnginear »
Scott
Looks interesting, but since there are no flow rates or other technical information posted can you post some video of yours in action. What color goes with yellow Mohawk hull?
It's a Howler!
sdbrassfield
Supporting Paddler
Post by sdbrassfield »
cheajack wrote:Should fit nicely in a boofing white Mohawk
I would agree...
PS: I think that Broam guy is a trouble maker...
SYOTR
jscottl67
Post by jscottl67 »
Scott (sdbrassfield), I think the flotation that James got for you and Richard might work better for you.
Agitation helps clarify. The water, I mean.
sdbrassfield
Supporting Paddler
Yep...Definitely a trouble maker...I KNEW IT !
Are you sure your middle name is not "Louie" ???
SYOTR
ezwater
Post by ezwater »
Admission of dense-ness. I've visited this thread three times, and I've visited woot.com twice, and I have no idea what "pump" is under discussion. :o
gumpy
Post by gumpy »
http://www.amazon.com/Barbie-Flower-Sho ... B001CA51CY
you missed the link in the first post?
Joe
