1. What is the right type of plastic pipe to cut up for ABS slurry? (replies of "ABS pipe" will incur the wrath of the river gods)
2. What is the optimal size to cut the pieces into? As small as possible?
3. Can I assume that the proper consistancy is just a bit thicker than paint?
4. Do I have to remove the vinyl pigment layer? What's the best way to do that? Acetone?
5. What's the best way to get rid of the remaining foam core? Sanding?
6. If I were to fill the void with Gorrila Glue, Marine Goop, 2 part Urethane epoxy, or anything else besides additional thin coats of ABS slurry- what will adhere the 1st coat of slurry to the hardened filler?
7. What would be the disadvantage of using ABS slurry exclusively? Poor shock absorbtion? Time constraints?
8. How hardened does the previous coat of slurry need to be before I can put on the next? Rock hard, or is still a bit tacky okay? Anybody have a guess as to the drying time for a thin-ish coat of slurry (at room temp)? If I'm gunna paddle the boat this weekend, I probably need to do more than one coat per day...
Hey, anybody wanna just do it for me?
Thanks in advance for the flood of detailed, first-hand information!
