Vynabond or Stabond
Vynabond or Stabond
Anyone know where to get this stuff in Ontario, Canada. Need ASAP as i'm trying to install some modifications to my Mike Yee oufitting before the weekend.
Jonathan Hutcheon
a.k.a Hutch
Jonathan Hutcheon
a.k.a Hutch
If youarein TO check with MEC http://www.mec.ca/Products/product_list ... 2736435680
or The Complete Paddler http://www.completepaddler.ca/ .
billcanoes
vynabond
I've seen Vynabond listed for sale at some swim pool locations - not sure if you have above ground pools that far north
Or try Mike Himself
He lives between Stouffville and Uxbridge and usually has glue in stock. Or Brian Shields - he is about 35 minutes north of Mike.
NRS carries both. I would use sta-bond. One can should do it for thigh strap patches, use 2 cans if you are doing a saddle too. Double coat the foam and patches. DO NOT turn boat upsidedown when finished glueing.
Dont get high on the fumes. Also prep surface with "methyl ethyl ketone" or MEK
"Don't Panic"
<a><img></a>
<a><img></a>
