Also, has anybody ever ordered a custom C-1 skirt where the tunnel is somewhere between center and kayak position? Would that even be worth it, or if it's close enough to even consider just using a kayak skirt should I just go with that?
Can I see a show of hands, how many people paddle a conversion WITHOUT a custom skirt?
America, show us your skirts! (Europe too)
MotorCityOC-1
Matt Johnson
RodeoClown
- BlackFly Canoes
The custom skirt is SO worth it, especially if you sit far from the back of the rim. Mine is about a 10 inch offset, and it's A LOT dryer than the kayak skirt I was using before, because it doesn't pull away from my back. I think it was $20 extra from Mountain Surf, and it doesn't take long for them to do it.
Jeremy
Jeremy
Custom skirt...
Kevin
I've paddled with both custom and standard (C1 and K1). Spend the extra $20 for the placement and the taller tube - we will be glad you did!
I guess my typical set up is further back than most, I've used the same off the shelf kayak skirt through three conversions...
bearboater
I first borrowed an Out-Skirts kayak skirt. This was a great skirt, but I couldn't find one to buy. Then I bought an off the rack Bomber Gear skirt. It was hard to put on & it leaked. Then I gave my measurements to Mountain Surf. For ~$20 they put a taller C-1 tunnel where I needed it. The Easy-On has never blown & it's dry.
bearboater
scott, i just saw the bulkheadish looking feature on the wavesport in your outfitting page, and i tihnk i will try something to that extent as well, i however will have thigh straps, and all that jazz. right now im working on finding a centered trim in my flirt. then i will go on to that. do you know how he attached the foam to the mount i saw a bolt, but what does it screw into?
cheers
-isaac
cheers
-isaac
