Do I need a custom skirt?
Alden
Post by Alden »
Hi Folks,
My old Mountain Surf skirt finally bit the dust. Of course this happened right as the rivers are finally up after a year of drought . . .
I just drove the local paddling store, and the best whitewater skirt they had, a Bomber Gear skirt of some kind, definitely did not fit my Prijon Pure XL -- the tunnel was way too far back.
Question: is it worth taking the extra time to order a custom skirt, with the tunnel moved forward? My old skirt was just a regular kayak skirt, and that fit fine, but I'm not sure about new skirts.
Does anyone have any opinions on the made-as-K1 Snapdragons, or Level Six skirts? (Those are the ones some of the other local shops have.)
Alden
TheKrikkitWars
Re: Do I need a custom skirt?
Post by TheKrikkitWars »
You don't need one, but if you have your saddle fairly far forward, you'll probably appreciate one.
Alden
Post by Alden »
I guess what I'm specifically asking is -- does anyone have any experience using any of the Snapdragon skirts -- the EXP, or the Armortex -- or the Level Six skirts on C-1s with normal Dagger pedestal configurations?
Any opinions appreciated.
Alden
Alden
Post by Alden »
I suppose I'd also love to know: What type of skirts are C-1ers using?
Just curious.
Alden
Post by Bob P »
I've got a custom-size Snapdragon River Trek skirt. It's very good overall, but I put on a little Goop to protect the edge where my paddle shaft tends to increase the wear. I would definitely buy another one. My boat has a weird cockpit, so I had to send them a template, but the skirt fits perfectly.
My favorites are old Mountain Surfs or newer Skirt Works.
Yes, I haven't purchased one in a while.
I do have an older Snapdragon that was custom made for the Groove, as well as a slalom skirt or two from them. I've always had a problem with them popping off, so they don't get used much. Not enough "skirt" material I think. Newer ones are likely different... can't say better or worse.
Alden
Post by Alden »
I think I remember that Snapdragon Groove skirt. :D Never did stay on great.
Post by Bob P »
You can increase the friction on a plastic rim by the addition of cloth electrical tape.
Alden
Post by Alden »
For the record, I purchased a Snapdragon EXP. Even with the moved-forward seat of my Prijon Pure C-1, it worked great. I'm back on the river!
Thanks for your help, folks.
Alden
johnd
Post by johnd »
Have a question regarding what size Snapdragon EXP you're using on the Prijon Pure XL. Thanks.
Ianonetwothree
Post by Ianonetwothree »
Stay away from level six everything.
PAC
Post by PAC »
https://skirtworks.com/" onclick="window.open(this.href);return false; Looks to be a reboot! :-)
Rand C1
Post by Rand C1 »
I agree with Sir Adam, I have had a pop dragon
Rand
Mountain Surf on my Cascade, Skirtworks on my Fink, both good skirts.
